displacement info
displacement info
i just ordered an 408 iron short block from texas speed and i look at the paper work the bore is 4.010 and the stroke is 4.000 now im not that smart but i think that sounds more like a 404 not a 408 can any one give me any feed back thanks.
That is a 404ci, you're right.
bore x bore x stroke x #of cyl x.7845
Usually 408's are a 4.030 bore with a 4" stroke.
call and ask. I'm sure they sonic test all the blocks...but I doubt there's an iron block that only tested to a .010 overbore... standard aluminum blocks go that far... I've seen iron blocks go as far as 4.060. Call and ask.
