Installing cam next week need one last....
run down of what I will need to have with me. I will have full acess to a shop with lifts and air tools Here is a list of what I already have:
TR 224/224 @112 lsa
TR Harded push rods
Comp 918's
More Performances valve spring tool
Ktech Oil pump (with two o-rings) just incase
JWIS timing chain
16 pen magnets
cam install gasket kit from TR
cam pre lube
I think that is all... just want to know if I am missing any thing?? And if you have any words of incuragement that would be nice too
TR 224/224 @112 lsa
TR Harded push rods
Comp 918's
JWIS timing chain
16 pen magnets
cam pre lube
Re: Installing cam next week need one last....
Definitely buy a few extra keepers, maybe a retainer or too also. (I lost about 3 keepers and 1 retainer.....)
locktite for the cam retainer and cam bolts...
I personally would not use the cam lube, just cover the cam in motor oil after cleaning it thoroughly with brake cleaner...
Take your time and have fun! It will turn out fine as long as you torque everything in carefully, and take your time!
Good luck!
Tommy
Good luck!
Tommy
Yeah, ditch the lube and coat it good with motor oil right before you slide it in. I've heard the lube can clog the lifters. I think Tommy pretty much covered it. Be patient on the oil pump pick-up tube bolt. Be sure to stuff a few shop rags down in the pan so if you drop the bolt it won't roll down into the bottom of the pan, or you will . Make sure you take them out when your done though.
Good luck!
Good luck!
You need everything except that cam. I'll take it off your hands!
I placed a towel over the headers to catch keepers that dropped. Also keep a pen magnet handy while working with keepers. Them keepers are evil.
One time I was searching for one for over an hour. It was inside the retainer. Definitly brain fade. Searchin for keepers will drive you mad but once they are found all is forgiven.
Cool... I will hopefully have the manifolds off at the will be one less place to have to look!!! I am also doing headers and tc at the same time
You will also need the air fittings to go in the spark plug holes. I've heard some of these cams are hollow and you need to clean the metal shavings from manufacture out of there to keep them from winding up in your engine. Also, you want to be as gentle as possible with that More tool, and don't twist it on a bad angle. This is one tool that probably should have been made out of steel. Oh and nice choice on the cam, that's the one I'm getting.
just lube up cam with a good coat of motor oil, be sure not to "bind" the cam bearings by sliding the cam sideways in the first bearing.
!LS1 11 Second Club
Sorry for the hijack and good luck on the install (for all)
