LS6 Heads and Cam
Old 09-09-2007, 03:43 PM
LS1BlackBird99's Avatar
Default LS6 Heads and Cam
Anyone know what kind of number gains one would see by adding stock LS6 heads and an LS6 cam to an LS1 motor?
Really just looking to get more power out of the car without losing daily drivability. Also do not want to have to get a cam where I have to change the springs at certain intervals. Really prefer a stealth cam or as close to stock as possible.
Old 09-09-2007, 04:20 PM
NemeSS's Avatar
if u add a ls6 cam with that u should atleast make 405hp with stock manifolds and tune, drivability should be no diff. from stock. pretty much a copy of
ls6 motor, upgrade springs to ls6 also
Old 09-09-2007, 09:38 PM
hnaskoct's Avatar
im also tryin to find out the same thing because im thinking about upgrading to the ls6 cam and heads and do i have to change the oil pump
Old 09-09-2007, 10:13 PM
Evans752's Avatar
I have a 2002 405 hp LS6 in my car with all bolt ons and when I had the LS6 Intake and MTI throttlebody FLP headers and went 11.77 and made 387rwhp on a mustang brand load dyno that ask for weight Hope this helps and GOOD LUCK
Old 09-09-2007, 10:19 PM
kenp's Avatar
Well, I have LS6 heads and a cam bigger than the LS6 and I didn't dyno even close to 405 hp. M6 with 4.11's and stock exhaust was 360 hp 355 torque.
Old 09-09-2007, 10:27 PM
hnaskoct's Avatar
did u get the heads worked
massls1guy's Avatar
some headers and a cat back would give you very good gains.
Old 09-10-2007, 08:29 AM
cam1999's Avatar
When NemeSS said 405HP...., he meant, at the flywheel,
You have about 414HP at the flywheel with 360 rwhp!
Old 09-10-2007, 09:32 AM
DANOZ28's Avatar
well i have this exact combo, i have posted this before. if you want a cam that idles at 600 rpm, with no loping sound / sleeper this cam is for you. do not expect great dyno numbers, i was dissapointed. you'll gain 20 rwhp from heads and 20 rwhp from cam. i'm a conservative guy and i wish i would have gone with a slightly bigger cam. i'm at 350 rwhp w/a4, before my TB. ther is a local dyno that gives inflated #s aprox 20-25 higher. good luck with your choice. ps i'm happy with my ls6 heads but wish i put bigger / higher lift springs on, mine are ls6 springs good to 570 lift.
Old 09-10-2007, 09:39 AM
wzup1000's Avatar
i dropped a ls6 crate from sdpc, and made 390hp 375tq at the wheels...
Old 09-10-2007, 04:15 PM
teke184's Avatar
go with a bigger cam
there are stealth cams for a reason
Old 09-11-2007, 05:14 AM
kenp's Avatar
I agree. The guy who did my tune told me my exhaust was holding me back. I'm finishing up my Kooks 1 7/8 install and adding a slp dual/dual. He said with headers and cat back we should see around 400 rwhp.
The answer to the question about the heads is yes. My heads are ported, I have the light-weight valves and higher ratio rockers.
Quick Reply: LS6 Heads and Cam
