will the LS7 stock cam work in a LQ4?
Old 09-13-2007, 01:20 PM
69LT1Bird's Avatar
Default will the LS7 stock cam work in a LQ4?
I was looking at the specs for the LS7 cam (pn 12571251) and they look pretty good for an overall driveable cam.
  • int lift = .593
  • ext lift = .588
  • duraton = int = 211 exh = 230
The springs are PN 12621428 are a good price at my cost of $111.00 for the set.
Will this work in my LQ4?
Old 09-13-2007, 01:36 PM
LS1curious's Avatar
I would clay up the piston to valve and then there is the issue of the camshaft position sensor. You could get a comp grind just like ti though.
Old 09-13-2007, 04:15 PM
Custm2500's #1 Fan
silver-mod-o's Avatar
GEN III vs GEN IV .... I dont believe it would work, cam sensor is in the wrong place...
Old 09-13-2007, 06:03 PM
3.4camaro's Avatar
That cam will be shitty. It was designed for the LS7 heads, which flowed AMAZINGLY on intake(hence short duration) but not as good on exhaust(hence long duration)
Get a real cam. It will drive better and make more power.
Old 09-13-2007, 10:47 PM
Grimes's Avatar
there are much better cams for your particular application for sale by the sponsors
from what you are saying, maybe something in the high 220's duration
Quick Reply: will the LS7 stock cam work in a LQ4?
