PTV clearence question
Will a TSP 224R and LPE heads milled Milled .055 work?
What pushrods will I need?
Finally, what compression ratio will I be looking at?...safe enough for pump?
thanks in advance guys
Thats a lot of mill, it might fit, what size valves do you have and what size head gasket are you going to use?
Use a compression caculator to find your compression, search for the calculatorthat is posted in this forum.
As for pushrods, buy a length checking tool and measure for yourself, that way you dont have to rely on Internet hearsay you will know exactly what you need..
