Compression Ratio??????
Old 09-23-2007, 10:29 PM
1999ssls1's Avatar
Default Compression Ratio??????
I am having a little trouble figuring out my (correct) compression ratio. Could someone please help? Mods are TEA Stage 2 5.3 heads milled 0.15, 3.622 stroke with stock crank, 3.905 bore with 6.125 compstar rods with Diamond flat tops Comp Height 1.315 Effective Volume -1.6cc, Cometic 0.40 head gasket, comp cam 612 612 240 244 on a 112 with 93 octane.
Thanks Alot
Michael
Old 09-23-2007, 10:51 PM
brad8266's Avatar
Use the search next time please, thats why we have it.Compression Calculator
Your heads are going to be about 61cc in volume.
Old 09-23-2007, 11:08 PM
1999ssls1's Avatar
Well I did use the search, but I keep coming up with different ratios with different calculators. I was just seeing if anyone could give me an accurate one.
Old 09-24-2007, 02:11 AM
brad8266's Avatar
Youre gonna be in the 11.2 SCR, 8.0 DCR area.
Old 09-24-2007, 08:29 AM
1999ssls1's Avatar
Thanks man
