What size belt do I need with an ATI 10% damper
Re: What size belt do I need with an ATI 10% damper
According to the ATI website ( http://www.atiperformanceproducts.co...ts/damserp.htm ), "Requires shorter serpentine belt. DAYCO part # 4060755."
Let me know if you can find any similar information regarding the req'd belt for the ATI on an F-car.
The belt on ATI's site is way wrong for a C5, I forget what the number was but its 1" shorter then the stock belt. The stock belt will work just to get you going though, I drove my car to the parts store to find the right belt.. The a/c belt I used was the same one that came with the ASP pulley.
Phillip- The belt # is DAYCO # 5060755.This IS the correct belt.I spent hours a couple of weeks ago trying to chase down a 5060758- which is what ATI had on their site.I evetually contacted Dayco and they stated they do not make a 5060758 belt.The gave me several close sizes and ATI said 5060755 was the best fit.. Now I see their(ATI) site says 4060755! WRONG. You can buy it through many of the national car parts chains. You can also cross reference through Summit a Goodyear belt.Good Luck
joelBink)
joelBink)
