Thoughts on Pennzoil 5W50 Synthetic Oil
Re: Thoughts on Pennzoil 5W50 Synthetic Oil
Too thick on the top end, and because it's got such a large viscosity spread, it's got too much viscosity index improvers in it. Stay far away from it.
If you're not burning oil, stick with a 5w30 or 10w30.
Although I have used this product in the past, I recently learned that the oil is NOT a true synthetic even though it is labled and priced as a synthetic.
Patman can give u more on this.
Based on the price rip-off factor alone, I would never use it again.
If you're burning oil, that Mobil 1 mixture works well, also you could try out Mobil 1 0w40, or Amsoil or Redline 10w40. Oftentimes though, someone who goes from Mobil 1 5w30 to Amsoil or Redline 5w30 will find their consumption is greatly reduced, since both of those oils are thicker than Mobil 1 (they are on the higher end of the 30wt range)
7 Second Club
Mixing 15w50 and 10w30 will give you roughly the same thickness at 100c (operating temperature) but it will also thicken up the mixture a lot more when cold too, so you'll end up with more engine wear especially on a cool morning (say 50F for example) By running the 0w40 viscosity, you're assured that the oil won't be excessively thick under those conditions.
