Worth it to install a cam without a decent clutch?
Old 09-28-2007, 02:36 PM
Scammer Alert!
Ricks99ls1's Avatar
Default Worth it to install a cam without a decent clutch?
Hey everyone, i was wondering my clutch is getting near extinction, and was wondering if it was even worth installing one without a decent clutch, my car will not see any track time, only street racing, 99% of races occuring from rolls, would i be ok with my stock clutch? I have seen many people running cams on stock clutches just wanted to know if its possible with the driving that ill be doing, Thank you Ricky
Old 09-30-2007, 12:09 AM
madclown's Avatar
Mods in sig with a stock LS1 clutch although it is fairly new approx 4,000 mi. It feels great, but I don't drop the clutch at high revs either.
Old 09-30-2007, 08:38 AM
Scammer Alert!
Ricks99ls1's Avatar
Ya i think i had better do a clutch first then
Old 09-30-2007, 08:50 AM
99FormulaM6's Avatar
i had a 224/224 cam put in at 35k miles and left it in for 30k miles on my stock clutch and when we pulled the clutch it still had a good amount of material on it...
Old 09-30-2007, 08:53 AM
Scammer Alert!
Ricks99ls1's Avatar
thats interesting, my car is at 65,000 and the clutch is getting pretty sloppy right now....
Old 09-30-2007, 11:45 AM
99blancoSS's Avatar
When you say sloppy do you mean it slips? If its slips a little from time to time a cam will eat it up. My tr224 finished of my stock clutch within a month, it had 60k on it and was a little suspect. It had slipped from time to time and had been abused really bad once during a 3rd gear burnout.
Old 09-30-2007, 12:57 PM
Heat Treat Pete's Avatar
I would put the clutch in first. A bigger cam would only make it worse. I see your street racing from a roll. I hope you have some street drag raidals to keep the tires from spinning. I think tires would be better idea now then a bigger cam. If you did put a bigger cam in you would be spinning the tires more. We wouldn't want you to lose to those Rustangs because yor tires were spinning.
Old 09-30-2007, 01:04 PM
PREDATOR-Z's Avatar
First fix what is wrong, get a LS7 clutch then think modding
