oil loss
oil loss
drive 2002 camaro 3 maybe 4 times a month went to check the oil that only has about 1000k or less of use and it is about 1 qt low. I just swapped to mobil 1 5-30 the car only has about 55k; any reason for this.
Try replacing the PCV valve, if it gets all gunked up it wont regulate properly and could be the reason why your burning oil. It only cost about 4$ and takes 1min to do. Its good to replace every so often.
