Compression question 72cc
Old 09-30-2007, 01:35 PM
99blancoSS's Avatar
Default Compression question 72cc
I have ls1 flat top piston with -2cc reliefs 238/240 113 lsa cam. What would 72cc afr's give me for compression?
Old 09-30-2007, 02:57 PM
deadmanTA's Avatar
With a stock CR it would take it down to about 9.4
Old 09-30-2007, 04:27 PM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
Tell me what gasket thickness you're going to run, how much your pistons are in / out of the hole, and I can figure it out for you. This is on a 347 correct?
Old 09-30-2007, 04:36 PM
JScamaro's Avatar
My calculations gave me 9.54 static compression with your setup and stock head gaskets.
