Using the stock LS1 Pushrods and Rocker Arms for 500hp application???
I'm wondering if I should use the stock LS1 rocker arms and pushrods for 500hp application? If not what can I use that's mainly for street use? I'll be running Patriot Performance 64cc Heads with Comp Cams Xtreme RPM High #54-424-11. My car is a 99 Corvette FRC that I daily drive in the summer and once a while take it to the dragstrip.
Cam Spec:
Cam Style: Hydraulic roller tappet
Basic Operating RPM Range: 1,500-6,800 RPM
Intake Duration at 050 inch Lift: 212
Exhaust Duration at 050 inch Lift: 218
Duration at 050 inch Lift: 212 int./218 exh.
Advertised Intake Duration: 265
Advertised Exhaust Duration: 271
Advertised Duration: 265 int./271 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.558 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.563 in.
Valve Lift with Factory Rocker Arm Ratio: 0.558 int./0.563 exh. lift
Lobe Separation (degrees): 115
Cam Spec:
I would upgrade the pushrods for sure. You can get a set of chrome moly pushrods from summit for like 87 bucks. You can keep the rocker arms but, if you upgraded them it wouldnt hurt anything probably gain you a couple hps.
