pic and a quick rundown of the new motor
its an iron block 408, callies magnum xl crank, oliver billet rods, custom wiesco pistons, afr 225's hand ported by tony mamo, comp xer 254/258 647/647 on a 112, beck sheetmetal intake with nitrous outlet direct port system jetted for a 200shot.
its going in a camaro with a rossler th350 with a t-brake and a 9" with a spooled 3.89 gear, with an aluminum center section and gun drilled 40spline axles
me and a buddy of mine are doing the hole build ourselves in his garage from the oilpan to the intake.
is there anyone else that have done big builds at home and what not. if so what kind of setup is it?
thanks,
david
thanks,
david
