Need help. Whats my SCR/DCR
Old 10-23-2007, 06:55 PM
nobreaks254's Avatar
Default Need help. Whats my SCR/DCR
I am building a 383 stroker and need to know what cc heads I should get. The short block is not assembled yet so I dont know how far the pistons are out of the hole. The pistons have 6cc reliefs in them. I am running a Comp Cam 238/240 on a 112 XER lobes. The lift is .605/.609. I dont have a cam card so I dont have the other specs.
I am looking at a used set of PRC ported 225 Darts that have been milled to 60cc. What kind of compression will these get me? I was told that will 64cc heads I would be 11 to 1, but I dont know on what gasket. Any help would be very much appreciated.
Old 10-24-2007, 06:01 AM
anyone have any help for me?
Old 10-24-2007, 06:23 AM
Thorny's Avatar
Assuming .006 out of the hole and a .060 gasket, I'm getting a SCR of 11.23 and a DCR of 8.20
Same deck and .040 gasket gets an SCR of 11.78 and DCR of 8.58
Looks like those heads would work great to me, the deck height isn't going to effect you to much, you have quite a bit of wiggle room with your gasket choices to make up for it. This was also assuming a 112 ICL, but that only changes your DCR about +.1 per degree of advance with that cam.
Old 10-24-2007, 07:47 AM
69LT1Bird's Avatar
I see 11.37:1 SCR and 8.57:1 DCR with stock .052 compressed head gaskets.
112 +4, if you grind at 112 +0 the CR is 11.37 SCR and 8.26 DCR, the DCR drops because the intake @51 abdc
0.006 0.050
Intake Duration - ID (first number) 287 238
Exhaust Duration - ED (second number) 289 240
Lobe Center Angle - LCA (also known as LSA) 112 112
Intake Centerline - ICL 108 108
Intake Valve opens - IVO 35.5 11
Intake Valve closes - IVC 71.5 47
Exhaust Valve Opens - EVO 80.5 56
Exhaust Valve Closes - EVC 28.5 4
Exhaust Centerline - ECL 116 116
Overlap 64 15
Old 10-24-2007, 12:31 PM
I dont think there is any advance ground into the cam.
Are the PRC ported Dart 225's any good. I havent seem much about them?
Old 10-24-2007, 12:39 PM
69LT1Bird's Avatar
This is with .052" gasket
Bore 4.03
ST = Stroke 3.75
RL = Rod Length 5.7
Number of cylinders 8
Deck Height (how much pistons come out of the hole) -0.006
Piston Dome or Dish (- for a dome + for a dish) 6
Compressed Head gasket thickness 0.052
Cylinder Head Chamber Volume 60
Static Compression Ratio 11.37 :1
Dynamic Compresion Ratio 8.30 :1
Rod to Stroke Ratio 1.52 :1
Bore to Stroke Ratio 1.07 :1
Old 10-24-2007, 12:53 PM
69LT1Bird's Avatar
This with a .045" gasket:
Bore 4.03
ST = Stroke 3.75
RL = Rod Length 5.7
Compressed Head gasket thickness 0.045
Static Compression Ratio 11.57 :1
Dynamic Compresion Ratio 8.45 :1
Old 10-24-2007, 04:33 PM
Thorny's Avatar
I guess I should note that my figures assumed a genIII motor with a 3.898 bore and 4.0 stroke. I see LT1Birds given figures for a genIV motor with a 4.03 bore and 3.75 stroke which will effect both SCR and DCR by about .1 equally compared to a genIII bore.
There is a calcutator in the stickies that is easy to use and will allow you to tinker and get your desired results by changing gasket thickness and chamber volume.
Old 10-24-2007, 04:38 PM
69LT1Bird's Avatar
I wasn't too sure what the engine configuration was exactly, I just went with a normal small block 383. nobreaks, give all of you information
Old 10-24-2007, 07:08 PM
2000 LS1 block
bore 3.905
stroke 4.0
rod 6.125
piston 6 cc relief
gasket to be determined (would like to use .040)
deck height unknown, assume -.006
cam 238/240 .605/.609 on a 112 Comp grind (no advance ground in)
cylinder head 60cc
Old 10-24-2007, 07:09 PM
I dont have Excel on my computer and I havent see a calculator I can use.
Old 10-24-2007, 09:10 PM
Thorny's Avatar
Originally Posted by nobreaks254
2000 LS1 block
bore 3.905
stroke 4.0
rod 6.125
piston 6 cc relief
cylinder head 60cc
Bore 3.905
ST = Stroke 4
RL = Rod Length 6.125
Static Compression Ratio 11.80 :1
Dynamic Compresion Ratio 8.60 :1
Rod to Stroke Ratio 1.53 :1
Bore to Stroke Ratio 0.98 :1
Old 10-24-2007, 09:40 PM
thanks!
So with the DR at 8.6 it should work right?
Old 10-25-2007, 06:20 AM
Thorny's Avatar
thanks!
I would be happy with it. You will be stuck using premium, of course. But with the quench you'll get from that .040 gasket you should be in pretty good shape.
Keep in mind though, with a DCR that high, if you ever decide to switch to a smaller cam you will probably have to pull the heads to change to a thicker gasket, or possibly different heads too. If you never plan on switching cams you'll be fine, but a 224/224 cam WILL require a head change, a 232/234 would only require a thicker gasket.
I realize since you're a stroker a smaller cam probably isn't going to be an issue, just some food for thought.
Old 10-25-2007, 12:27 PM
Yes I was thinking about that. I dont think I would ever go to a 224. Maybe a 232/234, but that should just take a gasket change. Thanks again!
Still undecided on heads. I think I am going to past on the PRC 225 Darts. Heard on too many possible issues. I wish I could afford the AFR's. Any ideas on a second choice?
Old 10-25-2007, 04:58 PM
Thorny's Avatar
I'm plenty happy with my Patriot 243's. A little over $1300 shipped gets you upgraded valves, springs, retainers, seals and chambers milled to your request. I'm not sure it gets much better for the money. If you've got the money AFR or T.E.A. Trick Flows are excellent products.
Old 10-25-2007, 05:33 PM
ExceSSive's Avatar
I have heard that many stroker kits sent the piston .010 out of the hole. I would be sure that it will only be .006.
