Ticking... Lifter?????
I'll try and make this as short as possible...
Car = 1999 WS.6 with 118k miles
Basically stock with the exception of Lid, K&N, SLP LM CB....
1 Month ago - Bent 3 pushrods (most probably due to over-rev)
Replaced pushrods with stockers from a Z06 Vette...
Have been driving the car for about a month... lately been noticing this tick/clanking noise that seemed to be getting progressively worse...
Last week, had the car at a shop scheduled to get a new Intake Manifold, Throttle Body, and LT's with ORY installed. We were doing many Dyno pulls before and after the parts install... total of 8 the whole day, however we never got to installing the LT's and ORY because my car started shuddering and shaking very bad as we started it up to pull it up on the lift for the LT and ORY install...
now... when I first brought the car in, we heard the noise, but alas continued with the install anyways... like i said we did about 8 dyno pulls... all went well, but noticed some detination at the top end around the 5.5 rpm range and the noise seemed to really stand out at that point...
the car dynoed at 301/328 stock before we did any mods... (just in case you were curious)
the car is over at CMS right now, Ryne over there belives it might be a lifter... i can't argue as i've always had a gut feeling of the same thing... However the problem seems to be totally random. He said after he towed the car to his shop, and started it up, the shuddering and shaking went away... almost as if a bad lifter or something started acting up once the car was ran hard (like on a Dyno all day)... maybe the heating of the oil making the lifter collapse???? make any since...?
what do you guys think?
I had the same problem where kept on breaking pushrods on no. 6... turned out to be a lifter - found out once I was doing my head/cam install. Check it out -
Wasnt until now that I swapped out my heads/cam I saw all the damage the pushrod did... check these out
1. Broken pushrod
2. Broken lifter guide
3. Hollowed out the lifter
1. Broken pushrod
1. Broken pushrod
1. Broken pushrod
All is great now that I replaced all the stuff... I put in new ls7 style lifters I picked up from texas speed and chromeoly pushrods from them as well. My stock head had a small gash in the pushrod guide - I replaced the heads as well with ported/milled 5.3s
If you need some stock lifters/pushrods I got some lying around for a rainy day, so I can spare some... Only cause I spent 25 bucks at a dealership just for a new pushrod which ended up breaking due to the lifter issue... what a waste that was
I may be wrong but I would think the cam would be ok if the bottom side of the lifter isnt messed up.
I think that might depend on how bad the lifter was damaged, my lifter looked the same as all the others on the part that makes contact with the cam. In your case, the pushrod was just bent and didnt snap like my 2 push rods did and left nice small pieces of metal pounding my lifter...
