how much more does iron block weight
If your concern is added weight, you can do a few things if you haven't already. Swap out K-member for a tubular K-member, and engine brackets. 40lbs weight reduction. Switch your flywheel to an aluminum or billet FW. Save 10 ~ 20 lbs there. Also, if still wanting more weight off, go for the front control arms and switch them to tubular ones.
Bottom line is, 70lbs is not a lot of weight to take off the car if you need to.
