Roll Master Dbl Roller Keyways- help!
Old 11-17-2007, 02:53 PM
Tainted's Avatar
Default Roll Master Dbl Roller Keyways- help!
Ok folks, need a quick bit of help. On the peice that goes over the snout of the crank with the keyways, what keyway is advance, retard, and 0? Im having some trouble getting this info and I need it ASAP so any info in much aprreciated.
Old 11-17-2007, 04:54 PM
5.3LJimmy's Avatar
There is a good write up w/ pics about 2/3's down the page in the cam guide here:
https://ls1tech.com/forums/generation-iii-internal-engine/327734-cam-guide.html
I also found this link:
https://ls1tech.com/forums/showthrea...er#post1259358
Good luck, and I hope this helps.
Old 11-17-2007, 10:46 PM
Tainted's Avatar
ahh yes that helped a lot. Thanks very much for that. Now I just gotta figure out how the hell to pull that thing off the camshaft...
