URGENT! Damaged threads on head
I've removed my cheap O'reilly header gaskets and I'm installing new copper ones. I was foolish enough to leave the Y-pipe attached and try to put the header back on this way. In the process I had two bolts (far outside) holding the header up in place while I slid the gasket in. The weight from the y-pipe pulled the bolt out and I'm not sure if this damaged the threads or if in the process of trying again I managed to cross-thread it. Either way the bolt will go in but it's definitely damaged and would have to be forced to continue all the way through. I have the aluminum LT1 heads from '97 and I'm looking for some other opinions on what to do.
A) Force the bolt in and hope it doesn't get too hard to push farther before it's completely snug
B) Chase the threads with a tap
If I use a tap I'm going to have to do it with a wrench because I can't fit a drill in there and the head is definitely not coming off. Is there some sort of thread chaser I can pick up that I don't know about?
you might want to look into helicoils. it'll make the threads stronger than they were originally. you'd first have to drill out the old threads, tap new ones in, and then insert the coil. Check it out. you should be able to get them locally.
I doubt the y-pipe exerted TOO much force on the bolts (unless the header was at some jacked up angle or something), so I would think a tap/chaser would work fine with a patient operator.
There's nothing wrong with the method you used, but you can't just screw the bolt in one or two threads and expect it to hold that much weight. If you only turned the bolt in a couple of turns you might get lucky if you follow the instructions you've already been given. That's a common metric thread. Next time screw that bolt in more than just finger tight. Short cuts don't always save time. This is a case in point.
