flow bench results inside!! Ported LS1 vs Ported 5.3 vs Ported LS6
There is alot of debate about cylinder heads and which castings produce the best results.. however it is well known that the ls6 heads consistently flow better then the ls1 or 5.3 heads but for some reason alot of people are under the impression that ported ls1 heads are worthless. So i got a pair of each of the heads and had them flowbenched to see the results. All of the heads were done by companies that are fairly well known around the ls community and all the heads were claimed to flow over 300 cfm. All the heads were flowed on the same bench using the same flow method as well. The result was that all the heads flowed pretty well
ported ls1 head with 2.02 & 1.57 valves (advertised as flowing 305 cfm@.600)
intake.......exhaust
.100 65 ....... 54
.200 134 ....... 103
.300 197 ....... 146
.400 242 ....... 176
.500 278 ....... 199
.600 300 ....... 213
ported 5.3 head with 2.02 & 1.57(advertised as flowing over 310cfm@.600)
.100 66 ....... 54
.200 134 ....... 109
.300 198 ....... 147
.400 245 ....... 185
.500 279 ....... 210
.600 296 ....... 222
ported ls6 head with 2.02 & 1.550(advertised as flowing 307cfm@.600)
.100 69 ....... 60
.200 137 ....... 121
.300 208 ....... 161
.400 258 ....... 195
.500 290 ....... 214
.600 306 ....... 223
as you can see the ls6 head outflowed the other heads pretty significantly throughout the flow range. The ls1 and 5.3 head were basically equal and the LS1 head actually had a slightly smaller runner then the 5.3 head (222cc vs 225cc). Hope these results help some people out.
.100 65 ....... 54
.100 66 ....... 54
.100 69 ....... 60
lol only the 5.3 heads were mine..i may be selling them though if you are interested. The ls1 heads are also for sell. By the way the combustion chambers were also measured on the heads, the ls1's had 64cc combustion chambers while the 5.3 and ls6 had 60cc's
Nice info, but it would help a little more if we knew who the porters were and when these heads were ported, since many of the cnc programs have changed over the years.
What was the port volume on the LS6 head? You mentioned 222cc and 225cc for the LS1 (I presume 241 casting) and the 5.3 head respectively. Also, do you know what valves are in each head? 2.02 on the intake is good, but what about details like brand or if there is a back cut on the valve head. Looking at the data I wonder if the LS6 head by any chance had nicer valves than the other two.
Thanks for posting up the info. It's a great reference.
The LS6s are definitely better. I mean look at .200-.500 the LS6 heads just about rape them in that category. Flow at .600 means jack **** when you dont have an intake to flow that much air anyways .. I've got ported 5.3s also that ill be putting on a bench soon and maybe whenever i get that done ill post my results.
