help neeeded! strange noise
Old 12-20-2007, 12:52 AM
1SicV8's Avatar
Default help neeeded! strange noise
so, last track pass i made i hear a funny noise come from the car after the car shifting into third as i passed the 1/4 mile mark, the noise sounds almost like a ticking, but really loud. or kinda like rap-rap-rap-rap.... constantly, but only while under throttle. i dont hear the noise at idle.
so far i checked the pushrods and rockers. and all were fine.
this weekend i plan to change/check the oil for metal shavings, etc. and possible check the lifters after that.
any ideas on what it might be or i should check?
car hasnt lost power, feels the same and oil Pressure is fine.
Old 12-20-2007, 03:34 AM
GoFast908Z's Avatar
and you said mine would go KABOOM first....
lol jk man.
Hope you figure it out soon!
Old 12-21-2007, 05:37 PM
418redz28's Avatar
my motor made that noise. it was very very bad. 2 broke rods and a broke piston, i couldnt belive that it even ran.
Old 12-26-2007, 08:47 PM
1SicV8's Avatar
HA! awesome. something to look forawrd to i guess ...
did ur car show any signs other then the noise. the car runs fine at the moment, no loss of power, etc
Old 12-26-2007, 09:23 PM
5.3LJimmy's Avatar
What brand of oil filter you running? My money's on fram.
Old 12-26-2007, 09:43 PM
blkbird's Avatar
Could be an exhaust leak....
Old 12-26-2007, 10:50 PM
1SicV8's Avatar
what does that have to do with anything? i actually have a mobil 1 oil filter....
i/we dont think so. its def sounding like a valvetrain issue
Old 12-26-2007, 11:29 PM
5.3LJimmy's Avatar
Because the fram filters restrict oil flow on ls1's, causing lifter tap at high rpms. Not your problem obviously. Are you running any additives in your oil? Lucas stabilizer will cause aeration and lifter tap also. It could be a worn pick-up tube o-ring as well. Just going off your description it sounds like lifter tap to me, and I have seen these 3 items cause that problem.
Old 12-27-2007, 04:30 AM
1SicV8's Avatar
gotcha. if lifter tap is super loud then it might be it.... lol
Old 12-27-2007, 10:51 AM
LS1TECH Sponsor
Schwanke Engines's Avatar
Just a thought, what about your converter bolts. I have seen where that can make strange noises.
