LS6 heads
Old 12-26-2007, 09:30 PM
jstero99's Avatar
Default LS6 heads
building an LS1 naturally asperated street motor do you guys recomend patriot stage 2 or stage 3 heads with 3.9 bore getting mixed opinion with the valve sizes with the small cubic inches motor does anyone have any experience with these heads?
Old 12-27-2007, 08:41 AM
sroach20's Avatar
what cam are you planning on running? are you planning on flycutting?
Old 12-27-2007, 10:47 AM
LS1Tech Premium Sponsor
Jason 98 TA's Avatar
Don't rule out the LS6 PRC cylinder heads!! Checkout the dyno section & I think you'll find the PRC heads outperform the competition for very comparable money!!
https://ls1tech.com/forums/dynamometer-results-comparisons/835635-new-budget-heads-cam-combo-numbers.html
450rwhp from stage 1 heads!!
http://www.texas-speed.com/shop/item...d=134&catid=40
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
