New budget heads/cam combo numbers..
Got a fresh baseline on my WS6, even though the only credible difference between the vehicle now and the last time it was on the rollers is the swap from a Pacesetter ORY and Magnaflow catback to a TSP true dual setup, it was also on a different dyno altogether, so the numbers should be taken with a grain of salt as to any "comparison".
Anways, the verdict:
Appologies for the quality, but for those having a hard time seeing it, the peak numbers were 441.97 whp & 408.72 wtq
Mods listed in the sig, I left fairly happy with the numbers considering the potential room for improvement from a set of improved heads and slightly more aggressive cam, but I'm focused on some suspension work and rear-end next, here's to low 11's with a full interior
LS1Tech Premium Sponsor
Great results from the PRC ls6 heads once again!
How do people not buy this head everytime considering the awesome pricing available for these bad boys!!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
I gotta admit Jason u got a mean set of heads there for no money at all..
Thats an impressive setup.
Could u tell me how much the heads are milled,which gasket.
If u add a Ported Fast to this car it's gonna be over 455RW with a fairly mild cam.
Very impressive setup..
Even if u add 4.10's it wont lose more than 10RW...
nice numbers man, if i only knew i could get numbers like that from those heads id get a set too, i like the tq # but other similar set ups seem kinda low on tq compared to yours, what did your car dyno with the previous mods before the heads?
Well the heads and cam went in together when I installed the new motor so I never dyno'd without both of them on. It initially made 400whp with the stock LS1 intake and TB, then 425whp with the LS6 and ported stock TB and some more PCM tweaking, and finally the 442whp with the TSP duals but again, this is on a different dyno so you can't take the numbers for face value as a comparison.
As far as the cam goes it's an 'off the shelf' Futral F13, 230/232 .595/.585 IIRC. Car was tuned initialy myself then further blessed by the hand of Mr. Formato
