a few cam questions.
Well guys, I think im finally starting to figure this out. I got the J-Rod/Pianoprodigy VE spreadsheet and it started to make sense of everything! Anyhow, from what I understand, for a street car, with pump gas you want too look for a DCR somewhere between 8.3-8.5. And a SCR of 11.0 or there abouts. Well, i started plugging in different cam combos, and came up with these 2: (Both are on Comp X-ER lobes)
232/240 .595/.609 112+4. This is with LS6 heads, and .040 gaskets.
234/242 .598/.610 111+2. This is with the same LS6 heads and .040 gaskets.
What I wanted to know was which of these combo's valve events looks better to you guys? Its going in a 01 M6 with 4.10 gear. Pump gas street car with occasional strip time. I would like to have 11's with the LS6 heads and cam. Im confident I can drive the car there if it has the mustard to do it. Thanks guys in advane.
Rodney Pierce
Rodney Pierce
