How much to mill stock 243 castings?
I have a set of stock 243 LS6 castings (not ported, stock valves, stock chambers). How much can I mill them and run a 232/232 .598 112 LSA cam?
1st concern is P to V clearance. Second would be too much compression. Is 11:1 okay with this cam and stock not polished chamber?
Was told to mill them 0.020 to get a 60cc chamber and 11:1 CR. (Engine is stock displacement).
Just double checking here.
Your compression ratio using stock gaskets and assuming the piston is .008 above the deck would be as follows:
Running 11:1 is okay as long as you run premium gas.
As far as PTV clearance, I'm not sure. I always check no matter what.
Ok, so I installed the cam and measured the clearance using the tester spring method. At the tightest point on the intake valve I had still have clearance with a 0.030 feeler gauge between the rocker and the valve. I will proabably just take 0.020 off the heads to be safe and be done with it.
These are stock 243 castings with stock valves.
