Cam to reach 390HP in an A4??
Old 07-04-2003, 10:24 PM
Nagash01WS6's Avatar
Default Cam to reach 390HP in an A4??
Im thinking about doing another cam swap... and Id like to hit the 390 range with the A4.
Current mods are in the sig... and I will soon be swapping out the converter for an SS3800.
I was thinking of something in the 228 to 232 duration range, .560 to .580 lift, and a 114LSA on stock heads.
Old 07-04-2003, 10:28 PM
*Bad Trader*
BYBYC5's Avatar
Default Re: Cam to reach 390HP in an A4??
224/224 560 560 106icl 110lsa
Old 07-04-2003, 10:44 PM
FYI... Put down 353 with the current setup.
http://www.fuelslut.com/kyle/scan0001.jpg
Uh... 110 LSA???? I want a resemblence of an idle.
Old 07-04-2003, 10:54 PM
*Bad Trader*
BYBYC5's Avatar
youd be surprised at what a little tunning can do...
ssfirefighter's Avatar
MTI C2!!! I hit 382hp and 357 with mild tunning by MTI, for the everyday driver. (it's 224/224 with a .581)
Old 07-04-2003, 11:09 PM
Ron@Vengeance's Avatar
What exactly is "mild tuning"?
Old 07-04-2003, 11:18 PM
How does the C2 idle???
The HotCam blows in that department, thats why I am looking for something with a 114 LSA. This will also be for nitrous usage, but I want 390 without touching the heads.
I like the looks of that R1 they have on there...
And what is mild tuning??? It took 8 dyno runs to get my car right... and the idle went to hell a week later... then the trans went to heaven. Still havent been able to get a decent idle out of the hotcam. Surges like crazy when Im slowing for a speedbump... stoplight... etc.
Old 07-05-2003, 12:51 AM
10secondZ's Avatar
Hey Kyle,
What's up man it's carter...Go with the G5X-2 114 LSA...makes wicked power..you should hit 390 or 400 with it..and with tuning it idles better than the hot cam..im getting it on a 112 LSA with my S2 5.3 liter's..I can't wait!..good luck bro.
Carter
Old 07-05-2003, 12:02 PM
Ragtop 99's Avatar
228/228 114 +4
I have that now. good idle @ 900.
230/230 113 +4 would make some good power.
Old 07-05-2003, 12:17 PM
I like the sound of 230/232 113 +4 on an XE-R lobe with about .580 lift both sides.
I dont like the amount of lift that the G5X2 has on the exhaust side, and the rather wide split in duration.
Where do you think max power would be on a cam that size??? Id like to keep to around 6500 to 6700, as I dont really want to do gears, but if I do they will be 3.42.
Old 07-06-2003, 07:01 PM
JS
JS's Avatar
I have a 224-228 581-588 113LSA for sale
Would do exactly what u want it to do...
Idles great in an auto with EDIT tune.
Sell for 225 SHIPPED!!!!!!
Old 07-06-2003, 07:19 PM
I might just go for the G5X2... not sure. I need to talk to a few people first.
