is it mandatory to change to a ported oil pump and DBR TIming chain?
Old 01-18-2008, 03:05 PM
xdanny510x's Avatar
Default is it mandatory to change to a ported oil pump and DBR TIming chain?
like the title says is it mandatory or is it just for saftey reasons?
Old 01-18-2008, 03:08 PM
Beast96Z's Avatar
Mostly saftey.
Old 01-18-2008, 03:09 PM
xdanny510x's Avatar
oh okiez thanksssss
Old 01-18-2008, 03:14 PM
Trev_SS's Avatar
Mostly Safety Reasons I didn't replace my timing chain and am thinking about going back in and changing it. I have been running stock timing chain and oil pump with heads and cam since july 2007 know haven't had a problem yet.
Old 01-18-2008, 05:30 PM
99Hawk262's Avatar
Agreed, I am still running stock chain and pump as well. I really didn't want the headache of changing them out and I figured if I had never done the cam swap, the stockers would have stayed anyway. I'll take whatever small amount of risk there is.
Old 01-18-2008, 07:12 PM
CAMAROZ28AQUINO's Avatar
im running stock pump and chain with no problems
Old 01-18-2008, 07:28 PM
xdanny510x's Avatar
oh shet i forgot to mention this for like 408 ....
Old 01-18-2008, 08:54 PM
bhz28's Avatar
if you are doing a 408 I would bet a new timing chain set and a ported pump, most people don't change them because of the extra work to get to the pump and lower part of the chain. With the motor not in the car there is just no reason not to.
Old 01-18-2008, 10:33 PM
jcolews6's Avatar
I was told I didnt need it but an LS6 pump and LS2 chain was only about $140. I thought it was a good bit of security. Its a lot of money and time to have something simple like a chain break.
Old 01-18-2008, 10:36 PM
BES Stroked Nova's Avatar
i always do a ported LS6 and DR chains on my cars, and most of the others i have done. I spin mine to 7200, so i wanted to "make sure" i have all the support needed.
Old 01-18-2008, 10:38 PM
Eatinstang4life's Avatar
Can run stock pump but change your chain for sure last thing you want is your stocker breaking!
Old 01-18-2008, 11:23 PM
if anything, change the oil pump.
Old 01-18-2008, 11:26 PM
crazylane's Avatar
How many miles are on the ones you have now???
And to all the people that still have there stockers, How many miles???
Old 01-18-2008, 11:29 PM
Phoenix 5.7's Avatar
the LS2 chain is pretty beefy, and u don't have to worry about double clearance. much beefier than the stock ls1 chain.
Old 01-18-2008, 11:32 PM
02 BLK WS6's Avatar
Although I wouldn't advise it, stock pump and chain with a cam/valve spring swap at 120k. Pump was still giving good pressure and the chain had minimal slack, so I left it alone.
Old 01-19-2008, 04:36 AM
james562's Avatar
I don't see why you could'nt get away with it...
But cmon 40.00 for a much beefer LS2 chain that will add 5 min to your install... why not?
The oil pump if your gonna see 6500+ It might be worth the investment to grab at least a new unported LS1/6 oil pump... If its a small cam that wont see much RPM (224 or less) I'd save it for later if your on a serious budget.
If its me I end up buying both why skimp 150 when your already @ 6-800 bucks
Old 01-19-2008, 06:59 AM
01Z28M6's Avatar
GM LS6 H/C at 65 thousand. Chain looked and performed like new, it has already proven itself to be reliable. As for the pump, mine (2001) is the last rendition scoggin dickey. It too is proven, reliable with no sign of a problem. I don't want to replace parts that are more than adequate, aren't broken or worn out. New parts can be defective or nearly out of spec from the manufacturer. Certainly old, worn or abused parts should be replaced while convenient. I know from sight, sound and performance that the parts in my engine are good ones. Loads of analogies but I won't go there.
