oil pressure too high?
Old 01-22-2008, 10:53 PM
Mart00SS's Avatar
Default oil pressure too high?
So I bought this 00 SS a month or so ago, ended up replacing the valve cover gaskets (they were leaking) found that inside the engine was gunked up some, not extremely bad but noticeable. So I ran some sea foam through it and changed the oil and filter with 10W30. Before this my oil pressure was at about 25 psi at idle and no higher than 60 while driving. Now I've got 40 to 50 psi at idle (engine warm) and close to 80 if you get on it. This seems like too much to me, so I changed the oil again, used a WIX filter instead of a fram and 5W30 oil, no change to the pressures. The gauge seems to be working properly and does not stick. Any info would be helpful.
Old 01-22-2008, 10:57 PM
z28berryhill's Avatar
no that is good....healthy motor...mine is the same way...and my freinds camaro also
Old 01-22-2008, 11:06 PM
Mart00SS's Avatar
Its got 140k on it im just a bit freaked out why it would go up 20+ psi at idle
Old 01-22-2008, 11:08 PM
hammertime's Avatar
Did you know the previous owner? What did the oil that you drained out of it look like?
Could have been that he knew he was selling it, and neglected to change it long enough that it broke down, lowering its viscosity.
Old 01-22-2008, 11:14 PM
88blackgt's Avatar
Originally Posted by Mart00SS
used a fram
ewwww
definitely stick w/ the wix from now on
Old 01-22-2008, 11:19 PM
if you redid parts of the motor like you were saying that is why the oil pressure went up ...i dunno if you hear no ticks in the motor and runs strong i think your okay
Old 01-22-2008, 11:20 PM
Mart00SS's Avatar
It was pretty dirty, but not to the extreme.
Old 01-23-2008, 01:32 AM
buddha845's Avatar
my car was the same way after a head/head gasket swap, seemed to run alot higher oil pressure but its been running fine for the 2 months after. (knock on wood)
EDIT: never hit 80 tho, i dont think
Old 01-23-2008, 01:46 AM
markzeronine's Avatar
yeah it's actually running right now.. the pressure shouldn't have been that low in the first place.
Actually I just noticed you said 80psi at WOT... isn't that in the red? That is pretty high alright. I'm sure others can chime in though
Old 01-23-2008, 04:55 AM
SOMbitch's Avatar
You're ok. Wish my OP that strong. Just keep the Fram off there. AC as cheap as Fram and much better.
Old 01-23-2008, 06:31 AM
SS101's Avatar
it should never really fall below 40psi with 5w30...even in the summer after a long road trip i'll still be seeing 35+
as for the high pressure, you've got to go a long way to do damage with high oil pressure - think hundreds - the worst case senario in your case is a blown seal somewhere. all in all, its nothing to be worried about, with OP its all about higher is better
Old 01-23-2008, 09:29 AM
bczee's Avatar
I would say that the Seaform did its job also.. cleaned up the oil passage and Oil system.
My stock 99' LS1 with only a LS6 oil pump runs a bit higher than yours at idle and around 80 at speed. (gauge only goes to 80psi LOL).
I would not worry too much.. just watch for oil leaks at the front and rear seal.
Old 01-23-2008, 09:34 AM
Eskimo's Avatar
Lemme play devils' advocate for a moment.
Let's say that the seafoam broke free a piece of something that's now lodged in an oil passage somewhere, restricting flow.. You'd see more pressure across the board, since pressure is just resistance to flow..
OTOH, there's not much you can do about it anyway...so just drive it.
Old 01-23-2008, 10:30 AM
BLACK2001SS's Avatar
I dont know what would brake free if it did its not the sea foam's fault all the see foam is going to do it brake down all that gunk and poo it out.
Oh and oil pressure sounds good to me.
Old 01-23-2008, 11:23 AM
99mongooSS's Avatar
yeah mine had a steady 40 at idle
Old 01-23-2008, 03:23 PM
Mart00SS's Avatar
This is exactally why I posted this, thought there could be a restriction somewhere, but if everyone normally has 40 psi at idle then nothing to worry about. I figured 25 at idle and 60 at speed was good for my motor with 140k on it. Maybe the screen had some gunk on it and was cleaned off with the sea foam.
Old 01-23-2008, 03:41 PM
SladeX's Avatar
40 at idle is about the norm for most LSx cars. Going WOT should see it hit 60's if not 70's. I just got complimented by the neighbours on a mean revving engine after I had done my oil change and was blipping the throttle and I had my eye on my PSI the whole time. I got it to blip a little past the 60 mark so probably in the 70's. Never seen 80 PSI though. I'll see what kind of PSI my Monte SS does but I suspect it's similar.
Old 01-23-2008, 04:58 PM
robertbartsch's Avatar
...pressure guages are not accurate.
...Oil weight has an impact on pressure.
Also, if the last owner changed the faulty factory GM oil pump, and replaced it with a high pressure one, it might cause some of this.
Old 01-23-2008, 05:09 PM
Braunbeck's Avatar
After I did the Sea Foam to my car it had better oil pressure.
Old 01-23-2008, 09:40 PM
Restricted User
2001 Pewter WS6's Avatar
I have the Mellings HV/HP pump and I have 65+ psi at idle,,,
