installing MS3, ported heads
Old 01-31-2008, 06:55 PM
geovett's Avatar
Red face installing MS3, ported heads
do i need 1.8 rockers or will my stock 1.7 work? 01SS, with 39k miles...
LS2 chain
ported LS6 oil p
duel springs
LS2 lifters
install is taking place in 2 weeks.................thanx 4 help
Old 01-31-2008, 07:02 PM
RE AND CHERYL's Avatar
I would at least stick with the stock 1.7 ratio. Most LSx cam grinders do not recomend rocker arm ratios above stock for anything but mild cams in the lower 220s. It shortens valve spring life significantly.
Re'
Old 01-31-2008, 09:05 PM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
I had the stock rockers on my PRC 5.3/ MS3 combo
Old 02-01-2008, 12:20 AM
SOMbitch's Avatar
NOOOOOOO!! Don't use 1.8's with a cam with aggressive lobes like that.
