Coil bracket bolt part number or size
I have a 98 T/A and am doing a H/C swap. I needed to buy the new center bolt valve covers and a new set of coil brackets because I couldn't use the old perimeter style. Now I need the bolts for the coil brackets. Can I get a part number or size from someone so I can pick them up?
Thanks
Thanks
The bolt is M6x1.0. I believe this is it:
http://www.sdparts.com/product/12560038/BOLT.aspx
It's strange looking, kind of like a stud with a nut screwed half way down it. I think a regular M6x1.0 bolt should be fine, can't remember if anything is mounted to the top of the stud.
