LS2 timing chain install
Old 04-04-2008, 03:42 PM
69 Ghost's Avatar
Default LS2 timing chain install
I am going to refresh an engine. Does anybody know if the LS2 timing chain damper works on a ls1 motor? The notes state that it is for high rpm applications but I am not sure that it will work on a LS1 block.
Old 04-04-2008, 06:01 PM
DrkPhx's Avatar
No it will not work because the length between the bolts is different for each dampner. GM makes a LS1 specific dampner.
Old 04-06-2008, 11:09 PM
Russ K's Avatar
My friend's 04 ZO6 block was drilled for the LS2 damper. The earlier (beige) damper with the wider bolt spacing is discontinued from GM.
Russ Kemp
Quick Reply: LS2 timing chain install
