X1 cam and 59cc 243 heads, will it clear?
Old 04-04-2008, 09:43 PM
VIPERBLUELX's Avatar
Default X1 cam and 59cc 243 heads, will it clear?
If I were to run some 59cc Patriot stage II 243's with GM MLS gaskets should I still have adequate p/v clearance with the MTI X1 cam?
thanks
Mark
Old 04-04-2008, 10:50 PM
jed.only's Avatar
only one way to find out...
Old 04-04-2008, 10:54 PM
cdoggy81's Avatar
Are they welded or milled to 59cc?
Old 04-05-2008, 03:17 AM
PREDATOR-Z's Avatar
I doubt it will, you have to measure
Old 04-05-2008, 07:17 AM
Eric Hawkins's Avatar
Probably will have to fly cut.
Old 04-05-2008, 09:18 AM
They're milled to 59cc, not welded, they are 243 castings.
Old 04-05-2008, 09:32 AM
JPH
JPH's Avatar
whats the cam specs?
Old 04-05-2008, 01:48 PM
Paint_It_Black's Avatar
Old 04-05-2008, 02:01 PM
PREDATOR-Z's Avatar
Originally Posted by Paint_It_Black
228/232 112+4
230/227 112 LSA
Old 04-05-2008, 02:03 PM
Tom@SpeedInc's Avatar
The exhaust lobe closes at 0, NBD
that intake valve opens very early 6º BTDC
Thats where your clearance issue will be.
Why not go with patriot heads with 2.02 or even 2.00" intake valves, pickup some extra room.
Old 04-05-2008, 02:20 PM
Originally Posted by PREDATOR-Z
230/227 112 LSA
OOPS! I was thinking of the G5X1
Old 04-05-2008, 03:37 PM
JPH
JPH's Avatar
230/227 112 LSA
well whatever it is, it would be to close for my comfort.
Old 04-06-2008, 01:37 AM
kingsey's Avatar
could u run a 224/224 .581 .581 on a 112LSA no problem with these heads?
