new setup:) tell me what you think!
I just wanted to get some opinions on my new setup!
AFR 205's milled and ported (tony Mamo) cosmetic gasket kit
228/230 114lsa
fast 92/nw90 ported (Tony Mamo)
Underdrive pully
Yella Terra rockers
ported oil pump
timming chain set
stock bottom end
my car is a 2000 ws6 m6 with 60000 on the clock. What kind of numbers do you think it will put down?
Thanks,
Nick
228/230 114lsa
Underdrive pully
Yella Terra rockers
ported oil pump
timming chain set
stock bottom end
Thanks,
Nick
I dont know...those cosmetic gaskets will make the engine look SOOO much nicer... LOL
j/k It should make some good power man, I bet you will not be disappointed.
228/230 114lsa
Underdrive pully
Yella Terra rockers
ported oil pump
timming chain set
stock bottom end
Thanks,
Nick
228/230 114lsa
Underdrive pully
Yella Terra rockers
ported oil pump
timming chain set
stock bottom end
Thanks,
Nick
Tony Mamo is still got the heads and Intake for porting. Therefore no numbers or driving yet but, I will be sure to post up when I get done with the build! P.S. Teardown sucks!
Your setup is almost identical to mine with the exception that my heads are untouched, I have a fast 90 nw 90 tb and my cam is a 228/228. I made 454 and 412. You will have a lot of fun with this combo on the street. Your combo will def suprise some of the big cam only guys Ask me how I know
Ya that is a small cam now that i think about it i stand corrected, but i do think that with the tony mamo ported heads and intake it would be good for over 450. My friends car made 433 RWHP through an LS6 intake with AFR 205s milled to 59cc, G5x3 cam ( alot bigger but still) and all trough a built 3500 stall trans. So i was thinking with better heads and intake its good for over 450RWHP for sure.
