What makes a camshaft "lopey"?
Old 08-07-2003, 01:47 PM
Crunch's Avatar
Default What makes a camshaft "lopey"?
I previously had a 224/224 .563/.563 114LSA cam. It sounded wicked. But I put on a blower and so I switched to a "blower" cam (218/224 .527/.534 LSA). I was worried that the new cam wouldn't sound as aggressive since it was "smaller." But lo and behold, it sounds even worse!
In that case, what is that really makes a cam sound "old-school"?
Old 08-07-2003, 01:55 PM
!LS1 11 Second Club
SouthFL.02.SS's Avatar
Default Re: What makes a camshaft
What's the lsa on the "blower" cam?
Old 08-07-2003, 02:03 PM
Colonel's Avatar
I bet it has a narrower LSA than your previous cam with the 114 LSA.
Overlap is what makes a cam "lumpy." The narrower the LSA and/or the more total duration you have, the more overlap you have.
Old 08-08-2003, 05:47 AM
EVIL's Avatar
i think that split duration might have something to do with that. i ran a 222/230 on a 114 before and it sounded nasty, now with the tr224 its kinda calm.
Old 08-08-2003, 02:29 PM
Crunch's Avatar
Sorry I forgot to put the LSA for the second cam. It is the same: 114.
In this case, maybe its the split duration. Because even though the lift and duration are smaller, I swear this cam sounds nastier.
Old 08-08-2003, 02:37 PM
niphilli's Avatar
Lobe Separation is the main contributing factor to the lope. The tighter the separation (lower numerically) the more it will lope. But as you have seen duration plays a role as well.
Old 08-08-2003, 03:30 PM
LawmanSS's Avatar
So would a 230/234 .560/.580 112 lope hard?...I hope!!
Old 08-08-2003, 03:49 PM
Cal
Cal's Avatar
It is the overlap that gives a cam its lope, but there are several factors that determine overlap. Cam duration, LSA, and ramp design. In your case, you probably went to a cam with less steep ramps so you wound up with more overlap. If the ramps had been the same, the new cam would have had less lope since the LSA is the same and it has less duration. Another factor is simply idle speed; maybe your engine is set to a lower idle speed than before.
The fact that it's a dual pattern cam won't make it lope harder, just a little rougher, if that makes sense.
Old 08-09-2003, 12:57 AM
DONAIMIAN's Avatar
why so small
lol
Quick Reply: What makes a camshaft "lopey"?
