JPR's New S2 Dyno Results **Dyno Sheet Now Scanned**!!!
We put the car on the dyno first thing this morning. Through a stock stall, full exhaust(no cutout) JPR's Head/Cam package....457rwhp/408 ft./lb SAE with a slight MAF problem.
Thanks to all the guys at JPR for a fantastic install! This car was better than I expected.
!LS1 11 Second Club
Re: JPR's New S2 Dyno Results!!!
Where are you guys? The web site is under construction. With those kinds of numbers, that's where I'm going when the time comes.
Specs please? Also, please PM me with the $$$ if ya don't mind. Thanks.
Not sure how fast it will run without any stall or gear, but that is some crazy power right there. Good Luck and u need to document some of these times. First as is, then add stall, then add gears and so on. Good Luck. Bear
You sure that there wasnt a leaky N2O tank nearby? Those dyno numbers just seem way out in left field if you ask me. What are the specs on that cam? With that kind of RWHP and a new torque converter and minor weight reduction, that car ought to be able to run in the high 10s...but I dont see that happening.
Great numbers, Joe makes some great packages especially if this is the cam he was telling me about.
With your car done hopefully I am one step closer to him installing my new cam.....right Joe??? Lately he has been like to get a hold of.
congrats joe! that is awesome that you repeated the numbers you were aiming for. your own car got over 450 hp (with an a4) and now this customers car.
the cam is big and requires notching the pistons, just like the other shops' big cams. if you wanna play, you gotta pay.
i wonder what that set-up will do in an M6?!?!?
If this is true... then in an M6 it would be the first stock cube... just heads and cam car to hit 500 rwhp?????????????????
Not calling B.S. but I know that it is some kind of "$hit".... whether it be bull$hit, or "the $hit", or the dyno is full of $hit....
Just do not seem possible with an automatic... I may be wrong though.
Joe told me he predicted you would hit north of 450rwhp with this car, because it was setup similar to his own car which did 450+ (also an A4 with stock rear). I think with stock stall that you are looking at an equivalent of 470+ on an M6 with 12-bolt, not 500rwhp, which supposedly has been done before.
Congratulations to you, Joe & the JPR crew!
Joe, call me please as soon as you get the chance.
how big is the cam though, I am putting in a set of his stage 2's here in a couple of weeks but I only have a 224 cam, I can't notch the pistons either so I will have to stay smaller.
let's see some track times...
