need a little help
Old 06-23-2008, 09:09 PM
nick123's Avatar
Default need a little help
took my heads off today and found that the number 3 piston has a couple nicks in the top of it. the cylinder walls are fine. im not sure what my options are. can i try and smooth out the top of the piston? the nicks and gouges are no more than 3 thousandths deep more likely less than that. or should i just replace the piston. any help you guys can give would be great.
Old 06-23-2008, 09:34 PM
DaveX's Avatar
Where are the nicks and what caused them? If they are not near the edge it's probably ok. Post a pic so we can see.
Old 06-23-2008, 10:11 PM
jsteele90's Avatar
a tap caused them. go ahead nick tell the story, its a good one.
Old 06-24-2008, 09:55 PM
jsteele90's Avatar
to the top
Old 06-24-2008, 10:00 PM
brad8266's Avatar
Not a big deal really, you can keep using them. Check the valves though to be sure they are fully seating and sealed.
Old 06-25-2008, 08:46 PM
jsteele90's Avatar
valves arent an issue he has new ls6 heads for it from TSP.
