5.3 GMC PU - sheared off exhaust bolts?
Sorry if this is the wrong section.
I have a 99 GMC PU W/5.3. Dead stock, 165K and running strong. Last week it started with a slight exhaust leak, what I found is that the back two bolts of the exhaust manifold on the DS are sheared off.
The bolt in the middle might be sticking out enough to get a visegrip or something on it, back one feels even with the head.
With all the miles on the engine I REALLY don't want to pull the head off.
Is this at all common for the bolts to do this? On my 93 LT1 it is common, but the LT1 heads have two bolt holes on the outter ports and after market headers use them. Does the 5.3 head have the same set up, or am I screwed? There isn't enough room to get a drill/easyout in there to remove the broken bolts with the heads on the engine.
Thanks,
Thanks,
I have seen this on at least a dozen or so trucks. Check the manifolds over real good. I have seen several with cracks. My old local dealership had them in stock! I have seen where the manifold had a buildup of rust, and it finally sheared the bolts from the pressure and thermal expansion. The factory bolts have some sort of threadlocker on them, and are pretty expensive. I use a right angle drill, with left hand drill bits. Starting with a small drill bit, and working your way up. A lot of times they will back right out with just the drill bit. If not an EZ out, or drilling most of it out, then using a punch to break out the last little bit. Proper tools and patience will pay off on this one.
Then I'll end up blowing the trans and such!
So I really need to leave the head on!
Thank you all for your help.
John
We do dozens of these a month on 5.3L's and mostly 6.0L's in 1-ton landscape trucks. Normally end up welding nuts onto them to get them out. Replace the manifold while your there. Usually snap because the manifolds start to warp and put excess strain on the rear port bolts. Aftermarket manifolds are cheap anyhow.
If warpage is a problem and these bolts are being sheared off due to expansion and contraction of the header flange(as opposed to breaking off due to vibration from loose header bolts) you might consider clear drilling the flange bolt holes a little to prevent this from happening again in the futrure. Apparently this is more of a problem in northern climates.
