Patriot stage 3's & MS3
As it says i have Patriot stg. 3 LS6's and the MS3 cam and i was wondering if anyone else is running this combo? I need to know what size pushrods to use, running the LS7 lifters and stock rockers. Just asking if anyone knows before i have to go buy the length checker?!!!
Yea thats a good way of checking, the only thing thats holding me back from buying the checker ( i know its only $20) is that im only gonna use it once, which i could sell it on here then!!
They are LS6 casting heads which will fit the LS1, BUT the PTV clearance is way to close, i forgot to mention that the motor is out and apart i am doing a 383 stroker build with Mahle -6cc dished pistons. TSP said as long as you have the valve reliefs in the pistons that combo will work, but yes i should get another opinion from Patriot!!!
OWN3D BY MY PROF!
Here's that thread:
https://ls1tech.com/forums/showthrea...alve+shrouding
OWN3D BY MY PROF!
On a smaller bore the 2.08" valve can result in poor bottom end torque because of valve shrouding and lower velocity. Also, PTV clearance is dramatically reduced over a 2.02" valve. Although the pistons have valve reliefs, they may not be large enough for the 2.08" valve. If you have any questions, please give us a call.
Patriot Performance
888-462-8276
