Heads
Heads
Help me pick a good pair of heads for my 226/226 112 patriot performance cam. I am looking for at least 400 hp. I have an intake manifold, throttle body, trual dual, headers, and slp lid.
i have a set of lingenfelter cnc heads that are just off my 383 LPE, my car is at the vette dr's now and should be done today. i went with tfs 215 that was the only reason for pulling them. i can work you a sweet deal..pm me.
400 HP is very easily attainable. We use the Total Engine Airflow Stage 1 ported heads and have seen between 425 and 445 RWHP with cams in the same range you are using. The great part is we can get you a set for well under $1500. There are alot of other ways to go using a more worked over head or even a trickflow casting. Though with your goals I know the TEA Stage 1's will suit your needs.
Thanks,
Leo
Thanks,
Leo
LS1Tech Premium Sponsor
I'd check out the PRC Stage 2.5 5.3L heads! They have a smaller intake runner than our competitors comparable 5.3 head so you don't have to spin alot of RPM to make great power and a price that fits your budget! Check out the dyno results section of this site and you'll find plenty of great results from similar camshafts to yours and these heads
http://www.texas-speed.com/shop/item...id=84&catid=40
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
It is a custom grind that Comp Cams did for me...not real agressive..makes good power and torque to the red line set at 6300..great daily driver that makes 375 ft lbs of torque at 3000 rpms..heads are TEA 5.3 stage 1.5 milled 30 thousanths
