PRC 5.3 Vs. TFS 215 cc
Old 08-06-2008, 08:58 AM
brandon2000z's Avatar
Default PRC 5.3 Vs. TFS 215 cc
ok so i decided that i was going to go with 5.3 heads and a torquer v.3 cam. but last night i was at work looking through a summit catalog and saw that trick flow had a h\c pack that made 515 hp and i did the math a the tricks would cost me around 600 more than the 5.3s after every thing else was bought (lifters? rockers?clutch? etc.) so what i want to know is the hp going to be that big of a diff. so which is going to make more power.
prc 5.3 stage 2.5 220cc and 2.02\1.575 valves
with tsp torquer v.3 231\234 .643/.598 with111 lsa
or
tfs 215cc intake runners 64cc combustion chamber 2.040/1.575 valves and 80 cc exh.
heads with tfs cam 228/230 .585/.585
both setups would use HS 1.7:1 rockers and a weiand lsx intake(if it ever comes out) or a fast 90/90
wondering if its worth extra 600 or if i should just use the 600 bucks to pick up a zex nitrous system
thanks
sorry for re post but old header sucked
Old 08-06-2008, 09:12 AM
69_YENKO's Avatar
is it still going to only be 600$ after you buy the new rocker arms etc.. for the TFS?
EDIT* just saw you plan to do rockers on either setup.
If you already had decided on the 5.3 I would stay with them that is a great head and will make good power, I also like the cam choice better with the 5.3's you could do better then that tfs cam . to me it sounds like your looking for a reason to go ahead and talk yourself into getting the TFS heads. if thats the case then just do it because later on down the line your probably going to kick yourself for not doing it.
Old 08-06-2008, 09:17 AM
yeah after the motors all done there will be only 600 difference but i could use that for zex
Old 08-06-2008, 09:26 AM
PREDATOR-Z's Avatar
You should use that $$ for tuning, lots of it to maximise your combo
Old 08-06-2008, 09:46 AM
ive included everthing and price diff is 600 after the motor down to the tuning and suspension
Old 08-06-2008, 10:17 AM
Dragkid1917's Avatar
trickflows and dont think twice...
Old 08-06-2008, 10:23 AM
98camaroLS1M6's Avatar
TFS 215s but go with a bigger cam like that Trak cam. Why would you get a better set of heads and go with a smaller cam?
Old 08-06-2008, 11:06 AM
its a package deal i havent looked at anyother cams for tfs what goes good with them
Old 08-06-2008, 02:05 PM
JScamaro's Avatar
Check out Vengeance Racing's website. You can get the Trickflow heads and a cam seperate. They have many popular grinds that work well with the Trickflow heads.
The package from Summit is a good deal though imo.
Quick Reply: PRC 5.3 Vs. TFS 215 cc
