how will this cam idle ??
Old 08-28-2003, 03:06 PM
Yelo's Avatar
Default how will this cam idle ??
210/230 .534/.544 111 lsa custom grind cam....this cam was computer designed to provide the highest possible torque curve form idle to 5500rpm
I figure it will lope a little.....but not too bad
I can provide complete specs including ramp profiles if it will help answer the question.....
Old 08-28-2003, 03:09 PM
2000Z28M6's Avatar
Default Re: how will this cam idle ??
That cam has a big split pattern compared to what most people run here. But yea probably just a lil rough due to the diffrences in the intake and exhaust duration.
Old 08-28-2003, 03:11 PM
someday's Avatar
is it for the truck? y 20 degrees more exhaust duration??
Old 08-28-2003, 03:16 PM
2000Z28M6's Avatar
UMM Look at his sig~!
Yelo's Avatar
the extended exhaust duration seems to bring high torque levels up sooner and hold the torque curve up much longer...... 400ft/lbs at idle and 476 ft/lbs at 4000....even at 5500 it's still making 400 ft/lbs (this is with Showroom Stock LS1 heads....just about the same flow numbers as stock 6.0 heads)
these numbers were achieved using Motion Software's Dyno2003 (proven accurate to +/-1%).....the numbers are at the flywheel with all accessories attached
Old 08-28-2003, 03:48 PM
2000Z28M6's Avatar
If you feel confident and are tech savvy why you askin? Just try it homie......
