head milling question
Old 08-30-2008, 07:51 PM
slowjoe99's Avatar
Smile head milling question
I have ported LS6 heads with 64cc chambers and an MS3 cam. the pistons I am putting in have -2cc valve reliefs. would milling the heads to 60cc's be too much? I am wanting to raise compression to make a little more power. I plan on running a 150 shot of nitrous sometime in the future.
Old 08-30-2008, 07:59 PM
NemeSS's Avatar
ptv clearnace check is the only real way to determine for sure.
i do not like to mill more than .030 of any ls head
Old 08-31-2008, 12:52 AM
F8L_LS1's Avatar
i think a mill of .015 would be ideal for you. correct me if im wrong, but i think that should get you to 62cc's = 11:1 comp with some cometic .040 head gaskets. with that, you should still be able to run 91 pump gas.
-f8l
edit: ^^ that was for stock pistons. for -2cc pistons, i believe you would want a .030 mill to achieve 11:1 compression (if thats what your looking for).
like nemeSS said, always check PTVC just to be sure.
Old 08-31-2008, 01:53 PM
slowjoe99's Avatar
so with 64cc chambers to start with, milling .030 off will give me 11:1 compression since i have -2cc valve relief pistons? will I still need to check the PTV clearance?
Old 08-31-2008, 02:03 PM
F8L_LS1's Avatar
i believe you will get 11:1 with a .030 mill. hopefully someone else can verify that.
its always nice to check PTVC just to be sure and have that extra feeling of safety, but... you dont have to.
Old 08-31-2008, 02:17 PM
Esco99's Avatar
Here abit of a useful help
http://www.c5frc.com/calculators/Com...Calculator.htm
Old 08-31-2008, 03:44 PM
Dragkid1917's Avatar
theres an even better one in some sticky.. it has like DCR and SCR based on valve events and some other BS like that. Also you could mill them .020 then run .030 gaskets and that would be very close to milling .030 and running .040 gaskets (granted your using stock .052 or .054's now). Because then if there was a problem, you could swap in thicker gaskets like the .040's and youd be golden.
Old 08-31-2008, 10:32 PM
slowjoe99's Avatar
Originally Posted by Esco99
thanks a lot! anyone know the height of a stock 2002 mls head gasket?
Old 09-01-2008, 12:51 AM
11Second Club
Gauge's Avatar
I don't think PTV is going to be an issue with the valve reliefs.
