High oil pressure after TR220 cam install. Please help
Just had a TR220 114lsa cam installed. At idle my oil pressure is about 55-60. Before the install it was always at 40 at idle. I adjusted the idle screw and enlarged the TB hole in the blade just a little. What is causing these high oil pressures, and is it something to be concerned with?
Thanks,
marco
Thanks,
marco
