LS3 Top End PCV Routing
Old 06-29-2011, 03:47 PM
oakley6575's Avatar
Default LS3 Top End PCV Routing
Hey guys, I just finished a 408 LQ4 with an LS3 top end. I have an LS3 drive by wire throttle body and I need help with my PCV routing. I will run the short crossover line from the LS6 Valley cover to the passenger side nipple on the manifold. I'm going to plug the Drivers side valve cover outlet, but where can I get fresh MAF'ed air from to the passenger side valve cover inlet?? Thanks
Old 06-29-2011, 03:49 PM
oakley6575's Avatar
I would like to run just the MAF and Filter on the throttle body. Not a long air tube. But it looks like I might have to in order to drill/tap the tube for a place to get fresh air from......?
Old 07-05-2011, 05:37 PM
Jimbo1367's Avatar
I am interested in this too. Subscribing. Might want to try a SEARCH
Old 07-06-2011, 01:43 PM
cam
cam's Avatar
Theres quite a bit of info on this topic here if you do some digging
Old 07-06-2011, 01:47 PM
oakley6575's Avatar
?? I can't find anything. Thats why I posted this thread. There is a lot of talk about PCV routing but everyone has dbc throttle bodies where you can find clean air. I can't find anyone who has a DBW throttle body.
Old 07-06-2011, 02:10 PM
cam
cam's Avatar
I see. Just plumb the fresh air side in the intake somewhere after the filter but before the tb. Should work fine lots of cars come this way even the GTO iirc.
Old 07-08-2011, 08:47 AM
1A Dan's Avatar
a lot of guys grab the fresh air right before the throttle body, just make sure you pull from a spot after the MAF. i've got a 90 bend right before my tb that i'm grabbing from, just had to add the nipple, but not something hard to do
Old 07-13-2011, 05:24 AM
haoping's Avatar
Question Your post is great
In the world the most comfortable shoes? christian louboutin sales promotion, in the world the most comfortable shoes? Five fingers shoes.
Quick Reply: LS3 Top End PCV Routing
