ls3 in my 02 ws6, whats it gonna take
so after dropping a lifter in my cam only ls1 that made 412/403 top the wheels at its prime i replaced it with a stock lq4 w/ epp boost cam, slp dbl roller, ls7 lifters, slp pump and katech rod bolts, that lasted a year,
i was racing a friend in his turbo camaro and the motor seized up, was having some oil pressure issues,
the next day it started but made all kinds of weird noises.
now i want to go back to aluminum and want an ls3
what do i need to make it work with my car (stock harness and pcm)
Knock sensors were moved to the side of the block and map sensor RTV'd and held down on the front of the intake so the computer is happy.
Hope this helps, I am not good at the internet/ wish I knew how to put pics up
Short rundown; Picked up a zero mile LS3 short block on fleabay. Took the rods and pistons out, ARP2000 rod bolts checked and installed. Piston rings gapped(stock was .006 on the top ring ) I didn't want to go further on a stock motor so the 58x wheel stayed in. SDPC LS3 heads and PRC spring kit. checked my pushrod length to put me .06 preloading the lifter on a custom 3 bolt cam on LSR lobes. If you use the 58x box make sure you have the 3 bolt 4 bump timing gear. Cleaned up the heads a little but nothing that would affect port velocity. Then topped with a complete intake/rails/injectors from fleabay. You wouldn't believe the final cost
Use injector adapters, cam trigger extension, map wiring extension, 5 wire 2002 Vett mass air flow with adapter and use a custom built LS3 with a 24 tooth crank. Re tune the computer for LS3 with five wire maf.
I already haf a vette maf with the Casper adapter.
so I will need
injector adapters
cam sensor adaptor/extension
58x adapter if I don't use a 24x wheel
is that it?!!
I wanna use the ls3 intake so I should get a 90/92mm dbc tb right?!?
Posted from LS1Tech.com App for Android
so I will need
injector adapters
is that it?!!
so I will need
injector adapters
is that it?!!
so I will need
injector adapters
is that it?!!
can I use my stock coils?!?
I am putting a brand new crate ls3 in my 2001 camaro. Here is a list of everything I have bought.
1.) Katech cam sensor extention harness
2.) Lingenfelter 58-24 trigger box
3.)ev1-ev6 fuel injector adapters
4.) Ls1 balancer and crank bolt
5.)90mm cable throttle body
6.) Slp Throttle cable bracket
7.) 85mm corvette maf
8.) 5 wire to 3 wire maf adapter
9.) Katech knock sensor extentions
10.) Ls1 windage tray, oil pan, and pick up tube
11.) Ls1 water pump
11.) Ls1 water pump
