LSX block mystery port and secondary oil pres point
What's the small 1/8" looking port on the left rear corner of the block, just off the valley cover? In between the steam port and the cover.
Also, where's a secondary port I can use for aftermarket oil pressure sender connection?
Thanks,
Charlie
Thanks,
Charlie
What I'm asking about is in the corner of the valley cover notch. Do you just have a bolt in there? Looks like you're using it for a ground?
Mine doesn't have that, I'm using a Milodon pan and the Oil filter is remote.
Charlie
Charlie
Thanks for the info. The guy that built my motor had taped it off, so I thought it was a port or something.
I was on Jegs last night poking around for a fitting like that but didn't see one. Looking at the driver side of the block, which port, left or right, is output and return?
Thanks,
Charlie
Thanks,
Charlie
