oil breather smoking. help!
i have a 2004 gto with a ls2 block built to a 402. it has an oil breather on it and is smoking after i run the car down the road.
what in the world is causing this.
Thanks, Shelby
Thanks, Shelby
I was having the same issue and was told to put a wrist band over the breather which will soak up the oil/mist. I see a lot of Pro/Mod car with some type of wrist band or fix up towel over the breather.
this is my breather location
the breather steams constantly when the the motor is up to temp. water vapor is a byproduct of heat in the crankcase. as you can see my engine bay is satin white and no oil mist gets anywhere in the engine bay. steam is normal. oil mist, oil smoke, **** coming out of the breather other than steam, is not
^^^ He is right. If you had your hood off and did some wot pulls you would get some oil out of it, but that is normal as well. Not a lot, but def some. You sound like you're in good shape.
