Shorter Runners for FAST Intake!!!
Old 05-26-2016, 03:35 PM
  #81
miami993c297's Avatar
Originally Posted by KCS
That's not 100% true. Most of the fastest all motor cars have a 4" crank or larger and they spin 9k+. The destroked engines are usually restricted to a cubic inch limit.
Make sense in drag racing, road course is another story.
Christian
Old 05-26-2016, 03:44 PM
  #82
Now KCS, if you are telling me you build engines 6.0 liters V8 revving to 9500rpm on a 4" stroke...that is nonsense.
Christian
Old 05-26-2016, 04:12 PM
  #83
The Scammer Hammer
dr_whigham's Avatar
You of all people should know what you can spin aluminum rods to, Christian... If the crank is perfection then I'd say even 12k is a reality. It's all in the valvetrain... Or an OHC head that's 100% custom...
Anyway, I think it's a typo and it should say 7.0
Old 05-26-2016, 04:55 PM
  #84
KCS
Moderator
KCS's Avatar
Christian
Uh, no. That's not at all what I said.
Old 05-26-2016, 10:19 PM
  #85
KW Baraka's Avatar
Originally Posted by Hardcoresoldier
The article also says it is a 6.0 LS7 yet the article also says the new runners are exclusively for square port heads....
In the video it's stated as a 6.0 LS3.
I'm gonna bet the video is correct.
KW
Old 05-27-2016, 06:44 AM
  #86
UNDER PRESSURE MOD
The Alchemist's Avatar
Until I see all three runners, on the same setup, it's pointless.... and I doubt they are going to show all three because it would be pretty obvious to people the amount you lose down low, compared to the amount gained up top... if they did that, they wouldn't sell many of these new runners that they spent plenty of r&d and production costs on.
Buyer beware.
Old 05-27-2016, 06:46 AM
  #87
UNDER PRESSURE MOD
I'm not saying they don't serve a purpose, because they do for those people only interested in racing where rpms don't drop below a certain rpm ever, like drag racing where you launch at x,xxx rpm, and during the shifts, it never drops below that point, but for the vast majority of people, even road racers, we don't live above those rpms.
Old 05-27-2016, 08:39 AM
  #88
KW Baraka's Avatar
Originally Posted by The Alchemist
Until I see all three runners, on the same setup, it's pointless.... and I doubt they are going to show all three because it would be pretty obvious to people the amount you lose down low, compared to the amount gained up top......
The only 'rub' I have is just how much would be lost below 3500 RPMs with the High-HP runners versus the Standard Length runners.
Still.....I got 3.70 gears on my A6 'SS'......so that's really just a minor concern.
The longer it takes Vararam to come out with their intake, the more likely I am to go with the FAST runners.
KW
Old 05-27-2016, 12:58 PM
  #89
blk00ss's Avatar
Really sucks they're not doing anything for us cathedral guys or ls7 for that matter...
Old 05-29-2016, 11:13 AM
  #90
HioSSilver's Avatar
KW
I would take a 20hp gain from 4k up vs a 30hp lose below 3500
True....not like it matters to me at all. Cathedral stuff gets no love anymore. But the msd seems very promising for the ls7.
Old 05-29-2016, 12:14 PM
  #91
SoFla01SSLookinstok's Avatar
I doubt that's where the shift in power would be.
Looking at the graph between the high hp & race runners. I would think the standard runners would make more power, than the high hp, everywhere up to around 6000-6500rpm maybe.
Old 05-29-2016, 01:14 PM
  #92
Hardcoresoldier's Avatar
Well, the LS3 guys NEED a manifold alternative to the OEM manifold. The only real alternative is a Super Vic as the regular FAST 102 is not an upgrade.
Old 05-29-2016, 01:16 PM
  #93
but the standard runners start to die off at 6000 and are done by 6200ish. Many of us want to spin to 7000 - 7500 which only leaves us with a Super Vic as an option. I'm not really concerned with power below 3500 as I will seldom see that in a race. I very much care about performance 5500 - 7500.
Old 05-29-2016, 01:46 PM
  #94
blk00ss's Avatar
This here.
Old 05-29-2016, 05:03 PM
  #95
KCS
Moderator
KCS's Avatar
Unless you can fit a Holley Hi-Ram.
Old 05-29-2016, 05:23 PM
  #96
the problem with that is nobody is running a high ram NA on a LS3. much less any comparisons of the LS3 high ram vs OEM LS3 intake.
Old 05-29-2016, 08:51 PM
  #97
David_viny's Avatar
Don't know if this has been linked yet but here is a vid of some testing:
Edit 10/08/16: Not my vid, just something I found.
Old 05-29-2016, 09:20 PM
  #98
I really wanna see what the mid length runners do out to 7500 now....
Old 05-30-2016, 07:56 AM
  #99
KCS
Moderator
KCS's Avatar
Ahem...
Tested Holley Hi-Ram LS3 intake vs Stock LS3, 45 rwhp gain on stock LS3 heads
Old 05-30-2016, 01:43 PM
  #100
Great video! It is all about the combo. As my motors power range is around 4500-6500rpm I would choose the longest runners. I don't think the bit of power up top, from the mid runners, would justify the losses through the band.
It's really awesome how you can tune the intake to the combo.
Quick Reply: Shorter Runners for FAST Intake!!!
