Electric Water Pump
http://www.jegs.com/i/Meziere/680/WP...YEdhoCUIrw_wcB
This allows for the same belt and routing to be used. Got ask the reason for the pump as they are a lot of money and only worth something like 8 HP.
Check out the new Meziere wp333. I just got it. I like it cause it will clear a FAST intake easily. It's about 5lbs lighter than the street pump and still has provisions for a thermostat and heater. I did have to exchange the inlet fittings with them for smaller diameter that fit the fbody hoses and looks like I'm gonna have to change the bottom radiator hose for a little bit longer one. I would just specify with wherever you order about what vehicle it's going in first. I think they have a straight up racing pump with no t-stat or heater provisions also.
