Broken water pump bolt
I just broke 1 of my lower water pump bolts on a stock LS 5.3!! Damned GM torque tight bolts!
How screwed am I?
Just about to FINALLY get my project on the road.
How screwed am I?
Did you get the pump off?
if you did get it off, the question is did the bolt freeze up in the pump or where it threads in to the block
Is the broken bolt sticking out of the hole so there is something to get hold of?
If so I would try putting some heat on just the broken bolt and as quick as possible put a pair of vise grips on it and try and work it back and forth a few times reheat and keep doing that until you can back it out of the hole.
The idea is the heat helps with rust or corrosion. If you know of some who has experience with this type of stuff that would help.
If if broke off flush or below the surface that usually is harder. in that case you need to drill it and use a easy out or drill and install a helicoil.
What ever you do take your time as I have seen many of these types of repairs turn into big problems.
I wish you luck
Knick
I wish you luck
Knick
I wish you luck
Knick
Hopefully there a enough threads left where i can at least put a nut on it and weld the nut to whatever is sticking out. I should be able to back it out then...
lesson to everyone.... 11-15 lbs of torque is just slightly over hand tightened
Naaah Knick... It broke off when I was trying to use 1 of those inch/lbs torque wrenches to tighten down those blasted GM 1 time use bolts ! Dogon thing never clicked at 11lbs so the bolt broke while I was installing the water pump, bottom right bolt.
as long as the bolt did not bottom in the hole I would think is would be loose in the threads and that would make it much easier to remove the broken piece.
Couldn't have been a worst outcome than I could imange...
broken off flush at the block. I tried to tack weld another bolt to it and then try to reverse it out but that didn't work....<br/>Sooooo now the real work begins...
If you use a easy out make sure you don't twist that off, or you will have problems
Hope it all works out
I had to completely drill out the broken bolt and rethread the hole. Purchased the ARP water pump bolts and now everything is ALL GOOD! drilled it slightly off center but I was able to get the water pump installed without any future issues
