LS3 Timing Chain Failure :(
#82
DrkPhnx, that link is bent outwards. I am assuming when the other link broke, the pressure of the tooth on the pin bent the other link out as the force was completely aborbed by that link.
#84
"Agree, they are physically different but they perform the task the same way the street versions do.
Agree and disagree. I'm still convinced the ATI damper offers better harmonic dampening than the stock damper."
Aaron,
If you think about the other end of the crankshaft, a full diameter cast flywheel is a better vibration damper than a lightweight small diameter race version, right?
Here is the C6R front dress> http://www.zorly.com/images_corvette...Race%20Car.jpg
Aaron,
#85
#86
I wonder why GM changed the design of the damper and went away from the LS2 design?
In this pic you can see where the chain hit the metal part of the damper and probably causing the plastic part to break.
#89
Have you asked the vendor for any type of test documentation that identifies the harmonic bands their damper is tuned for? I'm betting that would be an exercise in futility.
#90
Aaron,
Aaron,
A flywheel will absorb some vibration, but with the clutch its probably generating plenty of its own. The difference is the flywheel isn't designed to reduce engine harmonics like the damper is.
Cool picture of the C6R engine. The damper is covered up by the externally mounted reluctor rings. This is a good example of where a quality damper is really needed. The packaging constraints in this example require a custom design with a high degree of functionality. I'm sure the other end of the crankshaft looks just as exotic with a small diameter multi-disk flywheel/clutch assembly.
#92
Rob
#93
PM me if you don't get the crank pinning figured out; I have an ATI pinning tool.
#94
IN MY HUMBLE OPINION, the newer style is a better design. In motion, the timing chain will curve inward <drivers right> on the drivers left side of the timing set which both designs address. The drivers right side of the timing set will curve outward <drivers right> which only the new design addresses.
#96
Thanks for the offer for the pinning kit. Hopefully LPE can just take care of it for me. Drilling a forged crank won't be easy and will probably take more than one bit.
SIDEBAR: Vettenuts, I see you went with the Morels as well. What is the recommended preload on them? I read in a post once that it was something like .030 to .050.
#97
I'll install the newer design. With the TC damper, IRL chain and ATI balancer I hope my luck with timing chains changes for good. I'm even installing the Morel lifters due to reading this forum.
#98
I may be installing morels in my setup, but part of me just wants to use all of the stock stuff again so if a piston does happen to fail, I am not out any money for fancy aftermarket parts.
Speaking of lifters, does anyone think my current ones need replacement after this kind of a failure? I will be replacing the pushrods no matter what.
